NEWMOD Web GUI User Guide
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Accessing the WebGUI
To access the Web GUI:
Navigating the Interface
Web GUI Layout
Constructor
Pedalboards Library
Creating and organizing Banks
File Manager
  • Audio Loops & Samples
  • Impulse Response (IR) files
  • MIDI sequences
  • Instruments
  • Models
How to upload files
How to create a folder
Plugin Store
Installing New plugins
Plugin Info
  • URI
  • Author
  • Homepage (for the plugin)
  • Latest / Installed version
  • Plugin Description
Buying plugins
To purchase a plugin:
MOD Pedalboard Feed
List shared pedalboards using a particular plugin
On this page, you can:
  • Define user settings
  • Audio
    • Buffer Size
    • Sample Rate
    • DSP Load
  • System
    • Build Date
    • OS Version
  • Kernel
    • Machine
    • Release
    • Version
Basic
By default, that includes:
  • Banks
  • Pedalboards
Advanced
Audio Server
This section is mostly related with the needs of your pedalboard and how you want to use your MOD device in your setup.
Services
User interface
Workarounds
Device Updates
Dangerous
  • Clear favorite plugin list
  • Clear device settings
  • Clear plugin license keys
  • Delete all Banks
  • Delete all Pedalboards
  • Delete all Plugins
Please note that on the WebGUI the signals flow from left to right of the Constructor.
Despite that, on the physical devices, the signal flows as traditionally from right to left.
Creating a New Pedalboard
To create a new pedalboard:
  1. Click the Gui-new-pedalboard.png button on the interface.
  1. Drag and drop plugins from the Plugins Bar to the Pedalboard View.
  1. Connect plugins by clicking on their input/output nodes and drawing a connection.
  1. Repeat the first steps as many times needed to build your pedalboard.
Have fun with the endless possibilities of the MOD platform and enjoy finding your sound!
Plugin Connectivity
The plugins on the MOD platform can send and receive 3 types of data:
  • Audio
  • MIDI
  • Control Voltage (CV)
Audio Connectivity
The virtual audio cables on the MOD WebGUI have a purple colour.
Audio connections transmit virtually all audio between the plugins in your virtual chain, just like a jack cable would send audio from a pedal to another in a physical pedalboard.
Please note that there are plugins with a single audio input and a single audio output.
Other plugins with two audio inputs and two audio outputs, which means that they both receive and send audio in stereo.
Lastly, some plugins have a single audio input but two audio outputs. That means that, internally, the plugin receives the audio in mono, but can transform that same audio into a stereo signal.
MIDI Connectivity
The virtual MIDI cables on the MOD WebGUI have a cyan colour.
Control Voltage Connectivity
The virtual Control Voltage cables on the MOD WebGUI have an orange colour.
  • Monitor signal levels
Snapshots
  2. MIDI learn and mapping.
Managing Banks & Snapshots
Plugin Management & Store
  1. Installing new plugins.
File Handling
CV Usage & Modulation
Advanced Features & Settings
  1. True Bypass feature.
Troubleshooting & Support
  1. Common connection issues.
