File handling
Getting Started
How to upload a file
Available file types
Audio Files
- aif
- aifc
- aiff
- au
- bwf
- flac
- htk
- iff
- mat4
- mat5
- oga
- ogg
- opus
- paf
- pvf
- pvf5
- sd2
- sf
- snd
- svx
- vcc
- w64
- wav
extra through ffmpeg:
- 3g2
- 3gp
- aac
- ac3
- amr
- ape
- mp2
- mp3
- mpc
- wma
Audio Loops
Audio Recordings
Audio Samples
Audio Tracks
You can use this folder to store backing tracks for your songs, whether with multiple instruments or a single bass line (for example).
MIDI Files
For MIDI files basically.
- mid
- midi
MIDI Clips
MIDI Songs
Impulse Response Files
- aif
- aifc
- aiff
- flac
- w64
- wav
Currently, the IR file limit is 2048 samples (which is roughly 42.7 ms).
Instruments
Hydrogen Drumkits
SF2 Instruments
SFZ Instruments
For SFZ files, which typically have other audio file references within the SFZ.
Plugin Resources
AIDA DSP Models
NAM Models
Audio Files
MIDI Files
Impulse Responses
A high-fidelity cabinet simulator plugin that loads impulse response (IR) files.
Instruments
An SF2 loader/synthesizer.
Plugin Resources
An AIDA DSP Model loader
A Neural Amp Modeler Models loader
