NEWMOD Web GUI User Guide
- 1 Introduction
- 2 Navigating the Interface
- 6 Plugin Management & Store
- 7 File Handling
- 8 CV Usage & Modulation
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Accessing the WebGUI
To access the Web GUI:
Web GUI Layout
Constructor
Pedalboards Library
in the mode selection bar.
To access Banks, click on
Creating and organizing Banks
Use the
File Manager
- Audio Loops & Samples
- Impulse Response (IR) files
- MIDI sequences
- Instruments
- Models
How to upload files
How to create a folder
- Click on the
Plugin Store
To access the Plugin Store, click on
Installing New plugins
- Click on the plugin that you wish to install (in our case, the "GxQuack"), and the following screen will show up:
- On the plugin screen, click on the
button - After installation, the plugin will be added to the Plugins Bar. You can find it either in the "All" tab or the one corresponding to the plugin category (in our example, "GxQuack" is categorized as a "Filter" plugin.
Plugin Info
- Click on the Plugin in the Plugin Store;
- Click on the plugin in the Plugins bar;
- Click the
button at the top of the Constructor.
- URI
- Category (of the plugin - indicates where the plugin will be listed in the Plugin Bar)
- Author
- Homepage (for the plugin)
- Latest / Installed version
- Plugin Description
- External links (See it in action, See online, See discussion, See documentation)
- Control Ports (a table with the default, minimum and maximum value per control)
Buying plugins
To purchase a plugin:
- Navigate to the desired plugin in the MOD Plugin Store of your WebGUI, either by using the plugin highlights, scrolling through the store, or searching for the plugin in the search bar of the plugin store.
- Just like you would do to install a plugin, once you find it, you click on it.
- Here you can install a trial version, which will allow you to test the plugin before purchasing it.
- Once you decide that the plugin fits your needs and you want to purchase it, you should repeat the steps 1 to 3 to open the plugin description page on the plugin store
- Click the
button. - From here, a pop-up on the right of your WebGUI screen will appear with your shopping cart for the MOD Plugin Store.
- Repeat the process until here for any other plugins that you wish to purchase
- Once you have all the plugins that you wish to purchase in your cart, click on the "Checkout" button from the cart menu.
- A new tab in your browser with the MOD Checkout. There, you should insert your data and payment method and finalize the process.
MOD Pedalboard Feed
- Access the Pedalboard Library by clicking on
in the Mode Selector bar; - On the top right corner of the Pedalboard Library, you will find the button:
, click on it; - Listen to the samples and once you find a pedalboard you like, click on the Try Now button.
- open the plugin description dialog (for example, by clicking on the
info button on the top of the plugin on the MOD WebGUI); - click on the See it in action button.
- Go to the pedalboard constructor and click on
in the pedalboard actions bar. - Fill in the sharing dialog and (optionally) record a sample by clicking on the red circle.
- After finishing the recording, you can listen to it or record again.
- When you are done, click on the Share button.
The
button by the status bar (bottom right of the WebGUI constructor page) opens the WebGUI Settings page.
On this page, you can:
- Check information regarding your MOD device
- Define user settings
- Backup, restore and modify data in your MOD device
- Start the update process for your MOD device system or MOD Control Chain devices
- Audio
- Buffer Size
- Sample Rate
- DSP Load
- System
- Unit (your MOD device model/version)
- Build Date
- OS Version
- Kernel
- Machine
- Release
- Version
Basic
By default, that includes:
- Banks
- Pedalboards
- Device configuration (such as audio gains, Bluetooth config, etc.)
- All the plugins you have downloaded
- Insert a USB stick in the USB Host port (A) of your device. (Make sure the USB stick has enough disk space. Preferably, use a storage device with a FAT32 file system.)
- Check all boxes corresponding to the data that you want to back up
- Click "Backup user data..."
- Wait for the process to finish
- Insert the USB stick in which you stored the backup for your MOD device in the USB Host port (A) of your device.
- Check all boxes corresponding to the data that you want to restore
- Click "Restore user data..."
Advanced
Audio Server
- Duplicate a mono pedalboard output into both device physical outputs
- Separate S/PDIF outputs (only for available for MOD Duo X)
- Use 256 frames as Buffer Size
This section is mostly related with the needs of your pedalboard and how you want to use your MOD device in your setup.
Services
User interface
- Turn on the "Developer Mode". This will show you some extra meters and option in your MOD WebGUI
- Show beta plugins in the MOD Plugin Store of your device. You will be able to see listed and install beta plugins available in the MOD Plugin Store. These are plugins that have not been fully tested in the MOD platform and can have bugs and cause issues.
Workarounds
Device Updates
Dangerous
- Clear favorite plugin list
- Clear device settings
- Clear plugin license keys
- Delete all Banks
- Delete all Pedalboards
- Delete all Plugins
Creating a New Pedalboard
To create a new pedalboard:
- Repeat the first steps as many times needed to build your pedalboard.
Have fun with the endless possibilities of the MOD platform and enjoy finding your sound!
Plugin Connectivity
The plugins on the MOD platform can send and receive 3 types of data:
- Audio
- MIDI
- CV (Control Voltage)
Audio Connectivity
MIDI Connectivity
Control Voltage Connectivity
- Monitor signal levels
Snapshots
- MIDI learn and mapping.
- Installing new plugins.
File Handling
- True Bypass feature.
- Common connection issues.
