NEWMOD Web GUI User Guide
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Accessing the WebGUI
To access the Web GUI:
Navigating the Interface
Web GUI Layout
Constructor
Pedalboards Library
Creating and organizing Banks
File Manager
  • Audio Loops & Samples
  • Impulse Response (IR) files
  • MIDI sequences
  • Instruments
  • Models
How to upload files
How to create a folder
Plugin Store
Installing New plugins
Plugin Info
  • URI
  • Author
  • Homepage (for the plugin)
  • Latest / Installed version
  • Plugin Description
Buying plugins
To purchase a plugin:
MOD Pedalboard Feed
List shared pedalboards using a particular plugin
On this page, you can:
  • Define user settings
  • Audio
    • Buffer Size
    • Sample Rate
    • DSP Load
  • System
    • Build Date
    • OS Version
  • Kernel
    • Machine
    • Release
    • Version
Basic
By default, that includes:
  • Banks
  • Pedalboards
Advanced
Audio Server
This section is mostly related with the needs of your pedalboard and how you want to use your MOD device in your setup.
Services
User interface
Workarounds
Device Updates
Dangerous
  • Clear favorite plugin list
  • Clear device settings
  • Clear plugin license keys
  • Delete all Banks
  • Delete all Pedalboards
  • Delete all Plugins
Creating a New Pedalboard
To create a new pedalboard:
  1. Click the Gui-new-pedalboard.png button on the interface.
  1. Drag and drop plugins from the Plugins Bar to the Pedalboard View.
(add gif)
  1. Connect plugins by clicking on their input/output nodes and drawing a connection.
(add gif)
Adding and Connecting Plugins
  • Monitor signal levels
Snapshots
  2. MIDI learn and mapping.
Managing Banks & Snapshots
Plugin Management & Store
  1. Installing new plugins.
File Handling
CV Usage & Modulation
Advanced Features & Settings
  1. True Bypass feature.
Troubleshooting & Support
  1. Common connection issues.
