NEWMOD Web GUI User Guide
Revision as of 10:19, 11 December 2025 by Joao.sensiguitar (talk | contribs) (→‎Backup & Restore)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Accessing the WebGUI
To access the Web GUI:
Navigating the Interface
Web GUI Layout
Constructor
Pedalboards Library
Creating and organizing Banks
File Manager
  • Audio Loops & Samples
  • Impulse Response (IR) files
  • MIDI sequences
  • Instruments
  • Models
How to upload files
How to create a folder
Plugin Store
Installing New plugins
Plugin Info
  • URI
  • Author
  • Homepage (for the plugin)
  • Latest / Installed version
  • Plugin Description
Buying plugins
To purchase a plugin:
MOD Pedalboard Feed
List shared pedalboards using a particular plugin
On this page, you can:
  • Define user settings
  • Audio
    • Buffer Size
    • Sample Rate
    • DSP Load
  • System
    • Build Date
    • OS Version
  • Kernel
    • Machine
    • Release
    • Version
Basic
By default, that includes:
  • Banks
  • Pedalboards
Advanced
Device Updates
Dangerous
Creating a New Pedalboard
To create a new pedalboard:
Adding and Connecting Plugins
  • Monitor signal levels
Snapshots
  2. MIDI learn and mapping.
Managing Banks & Snapshots
Plugin Management & Store
  1. Installing new plugins.
File Handling
CV Usage & Modulation
Advanced Features & Settings
  1. True Bypass feature.
Troubleshooting & Support
  1. Common connection issues.
