NEWMOD Web GUI User Guide
Revision as of 10:08, 9 December 2025 by Joao.sensiguitar (talk | contribs) (→‎Adding and Connecting Plugins)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Accessing the WebGUI
To access the Web GUI:
Navigating the Interface
Web GUI Layout
Constructor
Pedalboards Library
Creating and organizing Banks
File Manager
  • Audio Loops & Samples
  • Impulse Response (IR) files
  • MIDI sequences
  • Instruments
  • Models
How to upload files
How to create a folder
Plugin Store
Installing New plugins
Buying plugins
To purchase a plugin:
MOD Pedalboard Feed
  1. Access the Pedalboard Library window by clicking on PedalboardLibraryIcon.png in the Mode Selector bar;
Additionally, you can list the pedalboards that were made using a specific plugin. To do this:
  1. Explanation of each main interface section (Pedalboard, Banks, Store, etc.).
Creating a New Pedalboard
To create a new pedalboard:
Plugin Info
  • Monitor signal levels
Snapshots
  2. MIDI learn and mapping.
Managing Banks & Snapshots
Plugin Management & Store
  1. Installing new plugins.
File Handling
CV Usage & Modulation
Advanced Features & Settings
  1. True Bypass feature.
Troubleshooting & Support
  1. Common connection issues.
