NEWMOD Web GUI User Guide
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Accessing the WebGUI
To access the Web GUI:
Navigating the Interface
Web GUI Layout
Constructor
Pedalboards Library
Creating and organizing Banks
File Manager
  • Audio Loops & Samples
  • Impulse Response (IR) files
  • MIDI sequences
  • Instruments
  • Models
How to upload files
How to create a folder
Plugin Store
Installing New plugins
Buying plugins
To purchase a plugin:
  1. Navigate to the desired plugin in the MOD Plugin Store of your WebGUI, either by using the plugin highlights, scrolling through the store, or searching for the plugin in the search bar of the plugin store. Just like you would do to install a plugin
  1. Once you find it, you click on it, just like you would to install any other plugin from the MOD plugin store.
  1. Explanation of each main interface section (Pedalboard, Banks, Store, etc.).
Creating a New Pedalboard
To create a new pedalboard:
Adding and Connecting Plugins
  • Monitor signal levels
Snapshots
  2. MIDI learn and mapping.
Managing Banks & Snapshots
Plugin Management & Store
  1. Installing new plugins.
File Handling
CV Usage & Modulation
Advanced Features & Settings
  1. True Bypass feature.
Troubleshooting & Support
  1. Common connection issues.
