NEWMOD Web GUI User Guide
- 1 Introduction
- 2 Navigating the Interface
- 6 Plugin Management & Store
- 7 File Handling
- 8 CV Usage & Modulation
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Accessing the WebGUI
To access the Web GUI:
Web GUI Layout
Constructor
Pedalboards Library
in the mode selection bar.
To access Banks, click on
Creating and organizing Banks
Use the
File Manager
- Audio Loops & Samples
- Impulse Response (IR) files
- MIDI sequences
- Instruments
- Models
How to upload files
How to create a folder
- Click on the
Plugin Store
To access the Plugin Store, click on
Installing New plugins
- In our example, we will use the search bar and type "GxQuack"
- Click on the plugin that you wish to install (in our case, the "GxQuack"), and the following screen will show up:
- The plugin will be added to the Plugins Bar.
Buying plugins
Creating a New Pedalboard
To create a new pedalboard:
Adding and Connecting Plugins
- Monitor signal levels
Snapshots
- MIDI learn and mapping.
- Installing new plugins.
File Handling
- True Bypass feature.
- Common connection issues.
