MOD Dwarf Device Settings
Updated for the MOD OS version 1.13
Audio Inputs
Notes:
- simply turn the knobs to fine-adjust the values;
Input Processing
Audio Outputs
Headphone Output
Output Processing
Sync
You can set the Clock Source to be Internal, over MIDI or Ableton Link.
Here you can define the MIDI Program Change Channel used to change your pedalboards and snapshots, if any.
- Audio Inputs: Everything under Audio Inputs
- Audio Outputs: Everything under Audio Outputs
- Headphone Volume: Everything under Headphone Volume
Before saving you must:
- Navigate to System Settings and change your settings
Display & LEDs
You should adjust this value according to your environment and viewing angle. Flat viewing angles may require higher brightness settings and vice versa.
LED Brightness
Turn the right-most endless knob to change the brightness of all the LEDs available on the MOD Dwarf.
You can set the LED brightness between Low and High according to your needs and environment.
Appearance
Control Header
Turn the central endless knob to define if the unassigned actuators should be shown or hidden on your screens.
These are the physical actuators that are not assigned to any parameter in your current pedalboard and also for the page that you have selected.
System Behavior
USB-B Mode
- Network (Default)
- Net+MIDI
- Net+MIDI (Windows)
Network (Default)
Net+MIDI
Net+MIDI (Windows)
Compensate GND Loop
Controller Behavior
Default Tool
- Tuner
- Tempo
Menu Button Mode
The different modes are:
List Behavior
In Direct mode, you simply need to have your scroll on the item and it will be selected.
In Click mode, you need to scroll to the item and then push the encoder to activate the selected item.
Menu Items
- Input 1 Gain
- Input 2 Gain
- Output 1 Gain
- Output 2 Gain
- Headphone Volume
- Clock Source
- Send Clock state (On/Off)
- Display Brightness
- Beats Per Minute
- Beats Per Bar
