MOD Web GUI User Guide
Updated for the MOD OS version 1.13
What is the MOD Web GUI?
How Does It Work?
For hardware devices (MOD Duo, MOD Duo X, and MOD Dwarf), the web server runs inside the device itself. Users connect to it over a network (via USB, Wi-fi, or Bluetooth) to access the interface. The connection to the network is not made using the Control Chain port (the RJ45 port) on the device.
Compatible Devices
Accessing the WebGUI
To access the Web GUI:
    1. For MOD Desktop you must:
      1. Open the MOD Desktop application
      2. Push the start button
Navigating the Interface
Web GUI Layout
  • Pedalboards Library: Quick access to manage pedalboards
  • File Manager: manage the storage available in your device
  • Plugin Store: plugin store where you can install and buy new effects and utilities
Constructor
  1. Pedalboard and Snapshot name: shows the name of the loaded pedalboard and snapshot
Pedalboards Library
  • load a pedalboard
  • delete pedalboards
  • Factory Pedalboards: Pedalboards that come pre-loaded on the device from the factory
Please note that the User Pedalboards can be deleted by using the Trash icon on the top right corner of each pedalboard preview.
How to load a pedalboard
Loading a pedalboard couldn't be easier.
On the Pedalboard library, click on the miniature icon of the pedalboard that you wish to load.
The loading process will immediately start and in a few seconds, your desired pedalboard will be running in your MOD device.
Alternatively, you can load it directly from the device. Yet, for this method to work, you should not have the MOD WebGUI open.
Check below how to load a pedalboard from your device:
Creating a Bank
Once created, a new bank is empty and ready to receive your pedalboards.
Populating a Bank with Pedalboards
To add pedalboards to your bank, drag them from the right lateral panel into the center of the screen.
You can add as many pedalboards as you want. It is also possible to add multiple instances of the same pedalboard to your bank (something that can be especially usefull if you use Program Change messages to switch between pedalboards).
Deleting Banks
On the left of the Banks window, you can see a list of all the User Banks available on your device. Note that factory banks won't be listed.
Next to each Bank name entry, you can see a small trash bin icon, just like this:
  1. To delete a Bank, click on for the line of the Bank that you wish to delete.
  2. Your browser will pop up a confirmation window
    1. Press "Ok" if you wish to proceed
    2. Press "Cancel" if you wish to abort the procedure
Note that deleting a Bank will not delete the pedalboards loaded into it.
File Manager
To access the File Manager, click on in the mode selection bar.
  • Audio Loops & Samples
  • Impulse Response (IR) files
  • MIDI sequences
  • Instruments
  • Models
You can learn more about the supported file formats on the File Handling page.
How to upload files
  2. Open the folder for the correct file type (Audio, MIDI, Impulse Response, AIDA DSP Model, etc.) and click on the button at the top of the window.
  3. A file browser window with access to your host device will open. From there, select the file that you wish to upload.
How to create a folder
  1. Click on the button
  2. A new screen will appear, where you will be prompted to enter the name of the new folder. Following our example, we will type "Water samples"
Plugin Store
To access the Plugin Store, click on in the mode selection bar.
Installing New plugins
  1. Click on the plugin that you wish to install (in our case, the "GxQuack"), and a screen similar with the following will show up:
  1. On the plugin screen, click on the button
Plugin Info
  • Click the Info button at the top of the Plugin UI in the Pedalboard Constructor.
  • URI
  • Author
  • Homepage (for the plugin)
  • Latest / Installed version
  • Plugin Description
Buying plugins
To purchase a plugin:
  1. Here you can install a trial version, which will allow you to test the plugin before purchasing.
  2. Click the button.
As soon as your payment is successfully processed, the license for the corresponding plugin(s) will be added to the device from which you made the purchase.
MOD Pedalboard Feed
Another great feature of the MOD devices is allowing you to share and load pedalboards from other MOD users on the MOD Pedalboard Feed.
  1. Access the Pedalboard Library by clicking on in the Mode Selector bar;
  2. On the top right corner of the Pedalboard Library, you will find the button: , click on it;
Note that to load an online pedalboard, you need to have the MOD WebGUI open and internet connection.
List shared pedalboards using a particular plugin
To share a pedalboard with the community, you should:
    1. After finishing the recording, you can listen to it, record it again, or delete it.
  3. When you are done, click on the Share or Just share button.
Please note that on the WebGUI the signals flow from left to right of the Constructor.
Despite that, on the physical devices, the signal flows as traditionally from right to left on the MOD devices.
Creating a New Pedalboard
To create a new pedalboard:
  1. Click the button on the interface.
  1. Drag and drop plugins from the Plugins Bar to the Pedalboard View.
  1. Connect plugins by clicking on their input/output nodes and drawing a connection.
  1. Repeat the first steps as many times as needed to build your pedalboard.
Have fun with the endless possibilities of the MOD platform and enjoy finding your sound!
Note:If you wish to remove any plugin from your pedalboard, click on the icon on top of it
Plugin Connectivity
The plugins on the MOD platform can send and receive 3 types of data:
Audio Connectivity
The virtual audio cables on the MOD WebGUI have a purple colour.
Audio connections transmit virtually all audio between the plugins in your virtual chain, just like a jack cable would send audio from a pedal to another in a physical pedalboard.
Please note that there are plugins with a single audio input and a single audio output.
Other plugins have two audio inputs and two audio outputs, meaning they both receive and send audio in stereo.
Lastly, some plugins have a single audio input but two audio outputs. That means that, internally, the plugin receives the audio in mono, but can transform that same audio into a stereo signal.
MIDI Connectivity
The virtual MIDI cables on the MOD WebGUI have a cyan colour.
MIDI connections transmit MIDI signals between the plugins in your virtual chain, just like a MIDI cable would send MIDI from one device to another in a physical setup.
Some plugins receive and send MIDI. Normally, those plugins are capable of transforming the received MIDI signal in a certain way.
Some other plugins only have a MIDI output. This means that they generate MIDI internally that can be sent to other plugins or devices in your chain.
Plugins like Generators or the MIDI to CV Converters receive a MIDI signal and convert it into some other type of signal. In the case of Generators, MIDI is typically converted into audio. Conversely, in the case of MIDI to CV Converters, the MIDI signal is converted into a Control Voltage signal.
Control Voltage Connectivity
The virtual Control Voltage cables on the MOD WebGUI have an orange colour.
CV allows modular-like control over plugin parameters.
You can use CV plugins connected and generate values that can be used to control most of the parameters from any Audio or MIDI plugins (and also other CV plugins) inside any of the MOD devices.
The MOD Duo X includes hardware CV inputs/outputs, which allows you to use CV communication also with external gear like modular synthesizers.
The hardware inputs and outputs on the MOD Duo X are represented in the inputs and outputs sections (respectively) of the MOD WebGUI constructor.
Note that plugins like the "Audio to CV" or the "Audio to CV Picth" are capable of inputting audio signals and outputting CV signals.
Plugin Control
Each plugin has a set of controls that allow users to set it up according to their needs.
This setup can be done either by directly interacting with the parameters on the plugin GUI (Guest User Interface) on the Pedalboard Constructor or by accessing the plugin parameter window.
How to access the Plugin Parameter window
On the top of each plugin in your Pedalboard Constructor you have the following set of icons:
There, click on
You will be forwarded to the plugin parameter window:
On this window, you have:
  • finer control over plugin parameters
  • most of the time, more parameters available. In other words, more control
  • access to the assignment window for each parameter (more info on how to assign a physical interface to a parameter here)
Proper gain staging helps maintain optimal sound quality. Use utility plugins to:
  • Monitor signal levels
Plugins that indicate how "hot" or "cold" your signal is in between some effects in your pedalboard - like the Level Meter- may be useful to help you with gain staging. Proper gain staging can help you avoid noise issues and achieve better sound quality.
Having problems with gain staging? Please reference the Troubleshooting page chapter to deal with gain staging.
Snapshots
What is a Snapshot?
In the "MOD world", a Snapshot works like a picture of the parameters on the plugins in your pedalboard at a specific moment.
They save parameter states within a pedalboard.
Snapshots allow you to quickly switch between different settings without reloading pedalboards.
This comes quite handy, especially when you consider that pedalboards take some time to load (depending on the amount and "heaviness" of the used plugins) and, for performance reasons, you may need an immediate change of multiple settings.
Let's say that you want to have different effects turned on and off in between different parts of a song and you also want to have certain parameters of each plugin in your chain dialed with other values. Snapshots are perfect for this job! They allow you to turn on/off as many effects as you want and simultaneously dial as many parameters as you want. They do it all for you, so you don't need to be an octopus to push hundreds of switches and dial thousands of knobs between your song's chorus and bridge.
How to access the Snapshot menu on the MOD WebGUI
Access the pedalboard snapshot menu by clicking on . Find it on the pedalboard actions bar.
Save pedalboard snapshots
  • To save the changes to the current pedalboard snapshot, choose the option Save.
  • To save a new snapshot, use the option Save as and give it a name.
Please note that the snapshots live inside the pedalboards; therefore, you must save your pedalboard after saving a new snapshot or modifying an existing one, otherwise those changes will be lost.
NOTE for MOD Dwarf users: on the MOD Dwarf, you can also save snapshots from the device. Please take a look here to learn how to do it.
Load and manage pedalboard snapshots
  • To load, delete, or rename a saved snapshot, use the option Load / Manage.
  • A pop-up window similar to the following will show up
  • On the MOD WebGUI, a single click on the name of the snapshot will load it.
    • You also have the option to assign the snapshot list to a physical interface on your device or on a Control Chain device by using the 'Assign all' button.
Another way to navigate the Pedalboard Snapshots is through an external MIDI controller connected to your MOD device.
For more info on how to set up your device for that, check the link to your device:
NOTE: the Snapshot list currently cannot be reordered on the MOD WebGUI, so some care must be taken when saving new snapshots to be effectively navigated with an actuator or via MIDI. Yet, on the MOD Dwarf, that's possible from the Navigation Mode on the device.For more info, check this page.
  • Save: saves the current state of your pedalboard under the same name.
  • Save as: saves a new pedalboard file under a new name that you are requested to input.
NOTE: on the MOD Dwarf, you can also save pedalboards from the device. Please take a look here to learn how to do it.
All saved pedalboards can be found and loaded from the Pedalboards Library.
One of the most powerful features of MOD devices is the possibility to assign pretty much any parameter to any control, either from your device or from peripheral devices.
How to create an assignment
To create an assignment:
  1. click on above the plugin from the parameter that you want to assign
  2. click on the icon, at the bottom-right corner of each parameter box, to open the assignment dialog box.
Note: For the presets list, you should click "Assign All" and you must have your list populated with more than one preset.
  1. a window with multiple tabs will pop-up, similar to the following:
  1. select the tab corresponding to the source controller for your assignment.
Note: Any parameter can be assigned, but some parameters can only be assigned to a specific type of interface. The interface will not list interfaces as an option that cannot be used for that specific parameter.
Preset lists can also be assigned.
Device
When you select the "Device" tab, you will be forwarded to a screen that allows you to create an assignment directly on one of the available interfaces of your MOD device. Check how it works according to your MOD device:
MOD Duo
If you want to make an assignment to one of the endless knobs or footswitches of your MOD DUO:
  1. Select the tab "Device"
  2. Select the control to which you would like to assign the parameter from the corresponding lists
  3. Click on the "Save" button
Note: the knobs of the MOD DUO can be assigned to multiple parameters (more info here), but footswitches can only hold one.
MOD Duo X
If you want to assign an action to one of the endless knobs, knobs, or buttons of your MOD DUO X:
  1. Select the "Device" tab
    1. On the MOD DUO X, you have a pagination system (learn more about it on Pagination and Switching Pages) that allows you to assign multiple parameters to each of the controls (endless knobs, knobs and buttons).
  2. Select the control in this window that you want to assign to the corresponding page
Take a look at the MOD Duo X User Guide to learn how to switch pages.
MOD Dwarf
If you want to make an assignment to one of the encoders or footswitches of your MOD Dwarf:
    1. Similar to the MOD Duo X, the MOD Dwarf has a pagination system.
    2. Yet, on the MOD Dwarf, you also have a sub-pagination system.
      1. The sub-pagination system is only available for encoders, allowing them to be mapped to multiple parameters on a single assignment page.
  2. Select the control in this window that you want to assign to the corresponding page and, in case the assignment is for an encoder, the sub-page
Check the MOD Dwarf User Guide to learn how to switch between pages and sub-pages.
The MOD devices have excellent MIDI capabilities, supporting both traditional MIDI connections and USB MIDI.
Check the type of MIDI connectors available on each device:
You can use both types of connections to input or output MIDI data, allowing you to assign MIDI Control Change messages to any parameter of your pedalboard, control Virtual Instruments (Generators) running inside your MOD system, among other possibilities.
Assigning plugin parameters to MIDI controllers
If you want to assign a parameter to an interface on a MIDI controller connected to your MOD device, after you access the assignment dialog box (which you can learn how to do at the beginning of this chapter), you must follow these 3 steps:
  1. select the "MIDI" tab,
  2. press save
  3. interact with the desired actuator (for example: push the button or turn the knob).
As soon as you interact with your MIDI controller and the assignment is successfully established, a pop-up message will appear in the top-right corner of your MOD WebGUI. Similar to the following:
Note: This assignment method is valid both for MIDI controllers connected via the MIDI input port or the USB-A port of your device.
MIDI Output
Some plugins have MIDI output ports, which generate MIDI data, such as MIDI Control Change, MIDI Note On/Off and other types of MIDI messages.
You can use this output to send data to other plugins or gear in your setup.
MIDI ports setup
The WebGUI MIDI setup is relevant to setting which and how the MIDI ports are displayed on the MOD WebGUI Constructor (inputs and outputs sections).
The MOD devices recognize your MIDI Controller when it is plugged in and add it to the MIDI ports list.
Yet, they are not directly visible in the input and output sections of the Constructor by default. To make them visible, you will have to enable them first by clicking on button on the Status Bar.
Here you can select between two modes:
Please note that controllers connected via the MIDI input (and not the USB A port) will not be differentiated, even when used with MIDI Thru, due to the limitations of traditional MIDI ports.
Aggregated mode
If you select the Aggregated mode all the MIDI ports from all the connected MIDI controllers will appear as a single MIDI Input and single MIDI Output.
This will not allow you to differentiate between controllers, for example, if you have two instruments loaded and want to use one MIDI keyboard to play a bass sound and another to play a lead sound.
Separated mode
If you select the Separated mode and activate multiple controllers on the MIDI ports list, those active controllers will appear with different MIDI input and output ports on the respective sections of the Contructor window.
To enable only the necessary MIDI controllers, select the ports that you want to enable and click on the Save button.
Now you should see the new ports added to the constructor screen.
This setup is ideal in case you want to use multiple controllers to play multiple Instrument plugins.
Virtual MIDI Loopback
If you check the Enable Virtual MIDI Loopback box, yet another new port will become available on the output section of the WebGUI.
This port allows you to send messages back into your MOD device, similar to what would happen if you physically connected the MIDI out of your MOD device back to its MIDI in.
Control Chain devices
Control Chain is an open standard developed by MOD Devices. For more info, check the Control Chain page.
In general, Control Chain devices (like the MOD Footswitch or the Arduino Shield) can give you a longer control range and also better visual feedback about what you are controlling directly in your Control Chain device.
Assigning parameters to Control Chain devices
To assign a parameter from your MOD pedalboard to a control chain device, select the tab "Control Chain".
You will get a dropdown list with all the interfaces available via the Control Chain port connected to your MOD device. Select the one that you wish to assign.
Assigning CV to Parameters
To make a CV assignment, you need:
  1. Enable a CV output from a plugin. This creates an internal CV addressing source.
  2. Assign it to a target parameter via the Assignment Menu.
To enable CV output ports, you need:
  1. Make sure that you have a plugin loaded in your pedalboard that outputs CV data
  2. Click on
    1. Check boxes will appear next to the outputs of the CV plugin(s) that you have in your pedalboard
  3. Select and label the ones that you want to use.
Done! After these steps, you have just made a CV output available to control any other parameter on your pedalboard.
Now, let's learn how you can assign it to any parameter on your pedalboard.
Assign CV output to a target parameter
To assign the CV control that you just created, you need:
  1. Access the assignment view for the parameter that you want this particular CV output to control. Learn here how to access the assignment window.
  2. Click on the "CV" tab
    1. All the available CV ports should be listed here
  3. Select from the list the one that has the name that you wish to control this particular parameter.
No Control Voltage list
If, when you click the CV tab, you see a screen similar to the one above, it means you have no Control Voltage output available.
If that's your case, please repeat the process described in "Enable a CV output from a plugin".
You will find plugins that output CV data under the Control Voltage tab on your Plugins Bar. Load one of them on your board just like any other plugin (check here how to load a plugin).
Note: If you have no Control Voltage plugins available on your plugins bar, head over to the store and you will find pretty cool ones for free.
If you have a MOD Duo X you can also use the Control Voltage connection to connect to external gear.
To use that feature, take a look first at the following links to learn how you need to set the device CV input and output CV connectors:
The MOD Duo X users will, by default, see two entries on the Assignment list when accessing the "CV" tab of the assignment window for any plugin parameter.
There, you will see the hardware CV/EXP input showing up as a CV addressing source.
Select from the list "Cv Exp Pedal" if you want to use an expression pedal or one of the two CV inputs ("Cv Capture 1" and "Cv Capture 2").
Setting up macro-controls with CV
CV controls give you lots of benefits. One of the most popular is the possibility to control multiple plugin parameters from a single physical interface.
Check this page to learn how to do it.
Advanced assignment settings
On any assignment type (Device, MIDI Controllers, Control Chain or CV), you also have an "Advanced" button that provides more detailed settings for the assignment.
  • Define a different label that you would like to be displayed on the displays of your device (only effective for device or Control Chain assignments);
Once you have done the adjustments, click on the save button to execute the assignment.
After saving, you should see the assigned information on the display (for device or Control Chain assignments) and be able to operate the parameter through the actuator you have chosen.
Advanced Features & Settings
System Settings
To access the WebGUI Settings, click on the button in the status bar.
On this page, you can:
  • Audio
    • Buffer Size
    • Sample Rate
    • DSP Load
  • System
    • Build Date (of the installed MOD OS)
    • OS Version
  • Kernel
    • Machine
    • Release
    • Version
Basic
Use custom Bluetooth device name: If you are connecting to your device via Bluetooth, you can define the name you want your device to show up.
By default, that includes:
  • Banks
  • Pedalboards
  • All the plugins you have
Restoring a Backup
Advanced
Audio Server
This section is mostly related to the needs of your pedalboard and how you wish to use your MOD device in your setup.
In the Audio Server section, you can:
  • Separate S/PDIF outputs (only available for MOD Duo X)
  • Use 256 frames as Buffer Size (useful in case your pedalboards run heavy plugins and the extra latency doesn't disturb your setup and needs).
Services
User interface
On the user interface section, you can:
  • Turn on the "Developer Mode". This will show you some extra meters and options in your MOD WebGUI
  • Show beta plugins in the MOD Plugin Store. You will be able to see the listed and installed beta plugins available in the MOD Plugin Store. These are plugins that have not been fully tested in the MOD platform and can have bugs or cause issues.
Workarounds
Device Updates (for connected Control Chain peripherals)
In case your Control Chain device firmware is outdated, you can also update it directly from the "Update firmware" button available on this page.
Dangerous
  • Clear favorite plugin list
  • Clear device settings
  • Clear plugin license keys
  • Delete all Banks
  • Delete all Pedalboards
  • Delete all Plugins
Monitoring CPU Usage & Performance
In the WebGUI status bar, there are meters for CPU and RAM.
It is useful to monitor these resources when building your pedalboard. Note that each plugin consumes a different amount of CPU and RAM.
Having problems with CPU and RAM management? Please take a look at our suggestions in the Troubleshooting chapter dedicated to managing resource-related issues.
True Bypass feature
If you use a MOD Duo or a MOD Duo X, those devices include a True Bypass system.
This system uses physical relays that directly connect the input to the output ports. Bypassing any plugin that you could have between them on the pedalboard loaded on your device.
"Bypass 1" connects the input 1 directly to the output 1 and "Bypass 2" does the same with input 2 and output 2 from the device.
You can activate it on the Status Bar of the MOD WebGUI.
Alternatively, you can use the Hardware Bypass plugin (only available on these two devices, Plugin Shop).
Using the Hardware Bypass plugin allows you to assign the hardware bypass to a physical interface, either directly on the device, a MIDI Controller, or a Control Chain device. Check here how to assign a plugin parameter to a physical interface.
Setting the plugin to Bypass Mode:
  • Left&Right: physically connects both pairs of inputs and outputs, bypassing your device totally.
  • Left: physically connects the input 1 to the output 1, allowing you to still use the pair input/output 2 for effects running on the MOD device.
  • Right: physically connects the input 2 to the output 2, allowing you to still use the pair input/output 2 for effects running on the MOD device.
Troubleshooting & Support
If you face issues with the MOD WebGUI, please refer to the relevant sections from the Troubleshooting page.
Appendix: Tips and Links
Direct links to MOD community resources
More than devices, MOD Audio is a community of music tech lovers, developers, and musicians, always eager to create something new and to share it with other community members.
This community is especially active in the:
MOD Forum
The MOD Forum is the home for our community to talk about their adventures with MOD.
Everything from tips & tricks, questions and feedback, troubleshooting, bug reports, feature requests, and new plugins can be found there, along with a discussion for each topic.
More often than not, plugin developers and the MOD team get feedback from there, and a lot of that feedback (either for a plugin or a system feature) comes from users with less developer skills but lots of ideas. Then, a lot of it makes it into a plugin or system feature.
More importantly, every feedback, opinion, or thought is welcomed with respect and constructive spirit.
If you are not yet a MOD Forum member, we strongly encourage you to create an account and participate.
Pedalboards Feed
The Pedalboard Feed is another place where MOD users can share their creations. This time on pedalboards to run inside MOD devices.
You can find everything there: from great guitar tones, excellent practice pedalboards, to crazy experimental sounds.
Most of the pedalboards are shared with audio samples, so users can quickly listen and check if that sound is what they are searching for.
In case it is:
  2. Open the WebGUI on a browser tab or window
  3. Press the "Try Now" button on the pedalboard you liked
Once you can read the message "Victory! Your MOD device is now loading the pedalboard you picked... Rock on!", the pedalboard should be loaded in your device. You can head over to the WebGUI window and see it there.
Now, go ahead and jam with it. If it fits your needs, don't forget to save it, just like you would do with any other new pedalboard.
The pedalboards feed is a great place to find sonic inspiration.
Plugins Database
On the MOD Plugins Database, you can check all the plugins available on the MOD Plugin Store, read their descriptions and specifications without having your MOD device around.
More than that, you can check all the pedalboards shared using a specific plugin. For that:
  1. open the plugin page for the plugin you want to check
  2. in the top right corner of the plugin description page, you will see a number stating the number of pedalboards shared using that plugin.
  1. By clicking on that number, you will be forwarded to the Pedalboard Feed with a filter only for pedalboards shared using the plugin.
The MOD Plugin Database is a great place to search for a particular type of plugin and listen to what it can do to your sound.
