Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
Headphone/CV Output
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- width: 163 mm
- length: 188 mm
- height: 63 mm
- 1st page: red
- 2nd page: yellow
- 3rd page: green
