Dwarf Device Settings
Audio Inputs
Notes:
Input Processing
Audio Outputs
Headphone Output
Output Processing
Sync
Before saving you must:
Display & LEDs
LED Brightness
Turn the right-most endless knob to change the brightness of all the LEDs available on the MOD Dwarf.
You can see the LED brightness between Low and High according to your needs and environment.
Appearance
Control Header
System Behavior
USB-B Mode
- Network (Default)
- Net+MIDI
- Net+MIDI (Windows)
Network (Default)
Net+MIDI
Net+MIDI (Windows)
Compensate GND Loop
Controller Behavior
Default Tool
- Tuner
- Tempo
Menu Button Mode
The different modes are:
List Behavior
Menu Items
- Input 1 Gain
- Input 2 Gain
- Output 1 Gain
- Output 2 Gain
- Headphone Volume
- Clock Source
- Send Clock state (On/Off)
- Display Brightness
- Beats Per Minute
- Beats Per Bar
