MOD Dwarf User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
- Use supplied adapter only
Concepts and Modes
USB Host port (USB port A)
MIDI I/O
For example:
Menu button
Display
Control Mode
Tool Mode
Tempo
