Dwarf Device Settings
Audio Inputs
Notes:
Input Processing
Audio Outputs
Headphone Output
Output Processing
Sync
Before saving you must:
Display
Appearance
Control Header
System Behavior
USB-B Mode
- Network (Default)
- Net+MIDI
- Net+MIDI (Windows)
Network (Default)
Net+MIDI
Net+MIDI (Windows)
Compensate GND Loop
Controller Behavior
Default Tool
- Tuner
- Tempo
Menu Button Mode
The different modes are:
List Behavior
Menu Items
- Input 1 Gain
- Input 2 Gain
- Output 1 Gain
- Output 2 Gain
- Headphone Volume
- Clock Source
- Send Clock state (On/Off)
- Display Brightness
- Beats Per Minute
- Beats Per Bar
