Dwarf Device Settings
The MOD Dwarf when powered up
Audio Inputs
Notes:
Audio Outputs
Headphone Output
Sync
Before saving you must:
Display
400px
400px
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Appearance
Control Header
System Behavior
USB-B Mode
  • Network (Default)
  • Net+MIDI
  • Net+MIDI (Windows)
Network (Default)
Net+MIDI
Net+MIDI (Windows)
Compensate GND Loop
Controller Behavior
400px
Default Tool
  • Tuner
  • Tempo
Menu Button Mode
The different modes are:
Menu Items
  • Input 1 Gain
  • Input 2 Gain
  • Output 1 Gain
  • Output 2 Gain
  • Headphone Volume
  • Clock Source
  • Send Clock state (On/Off)
  • Display Brightness
  • Beats Per Minute
  • Beats Per Bar
