Dwarf Device Settings
When inside one of the sub menus you can use the central and the right button pads to move for the next or the previous submenus on the settings list.
Audio Inputs
Notes:
Audio Outputs
Headphone Output
Sync
Before saving you must:
Display Settings
Behavior Settings
Default Tool
You can select between:
- Tuner
- Tempo
Menu Button Mode
The different modes are:
USB-B Mode
- Network (Default)
- Net+MIDI
- Net+MIDI (Windows)
Network (Default)
Net+MIDI
Net+MIDI (Windows)
Appearance Settings
Control Header
Menu Items
- Input 1 Gain
- Input 2 Gain
- Output 1 Gain
- Output 2 Gain
- Headphone Volume
- Clock Source
- Send Clock state (On/Off)
- Display Brightness
- Beats Per Minute
- Beats Per Bar
