Dwarf Device Settings
- Display Settings: setup the appearance of your device screen
- Behavior Settings: setup your device tools, Menu button mode and USB mode
- Appearance Settings: setup the appearance of your device screen on playing mode
Audio Inputs
Notes:
Audio Outputs
Headphone Output
Sync
Before saving you must:
Display Settings
Behavior Settings
Default Tool
You can select between:
- Tuner
- Tempo
Menu Button Mode
The different modes are:
USB-B Mode
- Network (Default)
- Net+MIDI
- Net+MIDI (Windows)
Network (Default)
Net+MIDI
Net+MIDI (Windows)
Appearance Settings
Control Header
Menu Items
- Input 1 Gain
- Input 2 Gain
- Output 1 Gain
- Output 2 Gain
- Headphone Volume
- Clock Source
- Send Clock state (On/Off)
- Display Brightness
- Beats Per Minute
- Beats Per Bar
