Dwarf Device Settings
The MOD Dwarf when powered up
  • Display Settings: setup the appearance of your device screen
  • Behavior Settings: setup your device tools, Menu button mode and USB mode
  • Appearance Settings: setup the appearance of your device screen on playing mode
Audio Inputs
Notes:
Audio Outputs
Headphone Output
Sync
Before saving you must:
400px
400px
The device settings on the MOD Dwarf are divided into two pages.
On the first page, you can make mainly visual adjustments like:
  • the Display Brightness
  • the Display Contrast
  • how Unassigned Actuators are represented
On the second page of Device Settings, you can also set some behavior settings for your MOD Dwarf like:
  • the Default Tool
  • what appears on the Control Header
  • the USB-B Mode
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Note: You can press the endless knob while turning to fine adjustments.
Default Tool
You can select between:
  • Tuner
  • Tempo
Control Header
USB-B Mode
  • Network (Default)
  • Net+MIDI
  • Net+MIDI (Windows)
Network (Default)
Net+MIDI
Net+MIDI (Windows)
Menu Items
  • Input 1 Gain
  • Input 2 Gain
  • Output 1 Gain
  • Output 2 Gain
  • Headphone Volume
  • Clock Source
  • Send Clock state (On/Off)
  • Display Brightness
  • Beats Per Minute
  • Beats Per Bar
