Dwarf Device Settings
(image of Quick items menu)
Audio Inputs
Notes:
Audio Outputs
Headphone Output
(replace with image bellow with image of Headphone Output menu on the Dwarf)
Sync
(replace with image bellow with image of Sync menu on the Dwarf)
(replace with image bellow with image of MIDI menu on the Dwarf)
On this menu, you can define MIDI settings for your MOD Dwarf. This menu allows you to define the MIDI Program Change Channel used to change your pedalboards and snapshots if you define any.
(replace with image bellow with image of User Profiles menu on the Dwarf)
To switch between users profile you simply need to turn the left most endless knob. This will allow you to swipe between all the user profiles. To validate the selection you should click the knob while the new User Profile shows us up to you.
(image showing this)
Before saving you must:
- Sync & MIDI
- Bluetooth
- Info
- System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
Pages Mode
Pot Calibration Mode
