Dwarf Device Settings
- Audio Inputs:
- Audio Outputs:
- Headphone Output:
- Sync:
- MIDI:
- User Profiles:
- Device Settings (1/2):
- Device Settings (2/2):
- Quick Items:
- System Upgrade:
To navigate between the items on the list of settings you should turn the left most encoder to right (going down the list) or to the left (going up on the list). To access an item menu on this list you should push the "EnterE button (leftmost button pad) or you can simply push the same encoder that you use to navigate on the list. To exit this menu you should push the "Exit" button (middle button pad).
MOD DUO
A: line level input
- Sync & MIDI
B: instrument level input
- Sync & MIDI
C: mic level input
- Sync & MIDI
D: internal sound generation
- Sync & MIDI
A: line level input
- Sync & MIDI
- Sync & MIDI
C: mic level input
- Sync & MIDI
D: instrument level input
- Sync & MIDI
- Sync & MIDI
- Bluetooth
- Info
- System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
Pages Mode
Pot Calibration Mode
