Troubleshooting Reinstall via LiveSuit
Different MOD Duo models
  1. Download https://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
  2. Click and hold down the FEL button on the back of the MOD Duo (in tiny hole), while you power it on
  3. Hold it for 2 seconds, then release
  7. Wait for the Duo to have blue LEDs and install Duo factory reset image (see #Step 7: Finalizing below)
Continue to step 6.
Continue to step 7
Step 7: Finalizing
