Factory Reset Images
They are useful if you want to reset your unit to its default settings.
Installing these images fully resets the user data partition! Make sure that you create a backup of your device if you don't want to lose any data.
Check here on how to create a backup of your device.
Release links
  1. Turn on your MOD
  2. Let it boot until you see it load a pedalboard
  3. Enter the settings menu
    1. For the MOD Dwarf, press the menu button left of the display and press the middle of the 3 small button on the right of the display to enter settings.
    2. For the MOD Duo(X) press and hold the left endless-knob until a menu appears in the display
    1. Note -> for the MOD Duo(X), turn the left knob to the "System" option and then the right knob to "System upgrade"
  5. Select 'YES' and while holding footswitch A (Dwarf), the left footswitch (Duo) or bottom left square button (DuoX)
If you don't have enough free space on your device to process the Factory Reset
If you can't process the Factory Reset due to a lack of storage on your MOD device, please back up your device's data and check How to delete files from the storage system of the MOD device.
