How to delete files from the storage system of the MOD device
ATTENTION!! Be extremely careful when deleting files from the internal storage of your MOD device, since you may not be able to access it afterwards!
WE RECOMMEND DELETING ONLY PEDALBOARDS AND PLUGINS FROM THE STORAGE
Using the WebGUI
Although it still requires careful use, through WebGUI is the safest method to delete files from the internal storage of your MOD device.
For that, go to the WebGUI Settings and then select the Dangerous sub-menu from the left side of the screen.
From there, you can directly delete Banks, Pedalboards, or Plugins by following the instructions on the screen.
Via SSH
This is the most risky method! Do it with special care!
To delete files from the storage system of your MOD device, you first need to access the MOD using SSH.
After accessing the internal storage, you can delete either a single file or a full folder.
To delete a single file, run the following command:
rm filename
To delete all files and folders in the current directory, you can use:
rm -rf *
