LV2 Basics
This information is well described elsewhere. The SDK assumes that you have a working lv2 plugin for desktop linux. If you haven't gotten that far, you should start with these links:
Prepare build tools
In order to run a plugin in the MOD Duo we must compile it for its specific architecture.
The Duo uses an ARMv7 processor running a very basic and stripped-down version of Linux.
Several audio-related libraries are included (fftw, libsndfile, libresample, etc) as well as generic libraries (boost, eigen, qt5core, etc).
We currently provide a custom build system that gives developers a similar system to what's available inside the Duo.
Do not use a regular Linux system, it might lead to issues due to mismatching library versions.
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.shThis process should take at least 1 hour, probably more depending on your CPU. When it finishes you'll be able to build plugins for Duo.
Using docker
Alternatively, if you're familiar with docker or are not running Linux, you can also use our mod-plugin-builder image which includes an already built system.
See this HowTo for more information about docker and mod-plugin-builder.
Build using buildroot '.mk' files
Get source code and create a '.mk' file
In case you haven't started your LV2 plugin yet just please follow through the links above in #LV2 Basics.
We have a few plugin examples available here. For this guide we'll use the eg-amp.lv2 example, already included inside of mod-plugin-builder.
The documentation for this file type is quite extensive, so it's not possible to cover everything here.
On the mod-plugin-builder repository (that you should have cloned before) there are many mk file examples under plugins/package/.
Compile it
We're all set to compile.
$ cd ~/mod-plugin-builder/
$ ./build eg-amp-lv2
$ ls ~/mod-workdir/plugins/
eg-amp.lv2Success, the plugin has been built. If you get an error of no-such file or directory, check that you have set WORKDIR the same as when you bootstrapped the plugin-builder.
Few things about the build script and Buildroot
A few important notes:
- If you want to rebuild after a change to your plugin or the .mk then it is often easiest to just delete the previous build's directory for your plugin ~/mod-workdir/plugins-dep/build/<packagename>-<version>
The '.mk' file will define how your source code is retrieved.
In most of the existing packages the '.mk' file tells buildroot to download the source. You can use a local tarball or point directly to the source code if you wish.
Just replace the top section with the following:
<PACKAGE_NAME>_SITE = /path/to/sourceMake sure to remove the <PACKAGE_NAME>_SOURCE line, if it exists.
If you try changing the eg-amp-lv2 example don't forget to remove the trailing path from the make command. It should look like this:
<PACKAGE_NAME>_TARGET_MAKE = $(TARGET_MAKE_ENV) $(TARGET_CONFIGURE_OPTS) $(MAKE) -C $(@D)If you place the source code in same folder as the '.mk' file you can set the <PACKAGE_NAME>_SITE like this:
<PACKAGE_NAME>_SITE = $($(PKG)_PKGDIR)/You can find a working example of such setup here.
Point to a local tarball
If you make a tar.gz file and put it in the same folder as the '.mk' file, you can replace the top section with the following:
<PACKAGE_NAME>_VERSION = 1.0
<PACKAGE_NAME>_SOURCE = eg-amp-1.0.tar.gzIf you want to use an arbitrary path just replace the <PACKAGE_NAME>_SITE variable.
Local development
For local development of plugins using buildroot can be bothersome and confusing.
You can use the cross-compiler and toolchain directly instead of going through buildroot methods.
Note that this expects that your source code build system is cross-compile friendly (ie, no hardcoded compiler and paths and uses pkg-config to find extra libraries).
Also this only works on a real Linux system, without using docker.
The setup is as simple as: (adjust as needed)
$ . ~/mod-plugin-builder/local.env <platform>
$ makeThe platform argument can be either modduo or modduox.
Quick example plugin
A quick example plugin is available inside mod-plugin-builder in make -C plugins/package/eg-amp-lv2/source/, which works with this cross-compilation setup.
Building this example plugin is as simple as:
$ . ~/mod-plugin-builder/local.env modduox
$ make -C ~/mod-plugin-builder/plugins/package/eg-amp-lv2/sourceThat's it! After this the eg-amp.lv2 bundle is ready to be deployed into a MOD unit.
Deploy it
$ modsdkThen open a browser at localhost:9000, select a plugin from the list and use the "deploy" tab to push the selected plugin's bundle to the Duo.
$ cd ~/mod-workdir/plugins/
That's it! Your plugin is now inside the MOD!
