How To Use Docker Toolbox With MPB
Pre-compiled image
To create a Duo image run:
Docker on an Apple M1 system to build Dwarf plugins
These are the steps to get the MOD plugin builder setup on an Apple M1 system.
Install the MOD plugin builder and create a Docker image using the following commands
cd ~
mkdir dwarf
cd dwarf
Executing
cd ..
git submodule init
./build moddwarf-new abgate
./build moddwarf-new guitarix
