MOD Duo User Guide
Headphone jack
General knob actions
Left knob actions
Right knob actions
General footswitch actions
- width: 160 mm
- length: 186 mm
- height: 75 mm
How to connect an Expression pedal
The MOD Duo does not include a direct port to connect an expression pedal. Yet, there are a few different ways to connect and use a traditional expression pedal with it.
Via Control Chain port
Via MIDI
Other options are MIDI controllers with already built-in expression pedals.
Hooking up the MOD Duo
