MOD Duo User Guide
Revision as of 13:39, 27 October 2025 by Joao.sensiguitar (talk | contribs)
The MOD Duo when powered up
Side-shot of the MOD Duo
Headphone jack
General knob actions
Left knob actions
Right knob actions
General footswitch actions
  • width: 160 mm
  • length: 186 mm
  • height: 75 mm
  • Off: below -40dB
  • Red: between -1dB and 0dB
Hooking up the MOD Duo
