MOD Duo User Guide
The MOD Duo when powered up
Side-shot of the MOD Duo
Headphone jack
General knob actions
Left knob actions
Right knob actions
General footswitch actions
  • width: 160 mm
  • length: 186 mm
  • height: 75 mm
  • Off: below -40dB
  • Red: between -1dB and 0dB
Hooking up the MOD Duo
Wiring examples
Guitar
  4. semi-accoustic setup
Vocals
  1. MIC -> MOD -> DI -> PA
  2.  ?
Keys
  1. HW Synth -> MOD
  2. ePiano -> MOD
  3. keyboard -> MOD
Exotic
TODO: Add exotic use cases
  1. Chapman stick
  2. Wind instruments
  3. Accoustic instruments
