MOD Duo Device Settings
On the left screen, you will see the main menu. The right screen will display the sub-menu related to the current item selected on the main menu.
Changing pedalboards using the footswitches
A: line level input
- Sync & MIDI
B: instrument level input
- Sync & MIDI
C: mic level input
- Sync & MIDI
D: internal sound generation
- Sync & MIDI
- Sync & MIDI
- Bluetooth
- Display Brightness
- Info
- System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
