MOD Duo Device Settings
On the left screen, you will see the main menu. The right screen will display the sub-menu related to the current item selected on the main menu.
Changing pedalboards using the footswitches
A: line level input
  • Inputs
  • Outputs
  • Sync & MIDI
B: instrument level input
  • Inputs
  • Outputs
  • Sync & MIDI
C: mic level input
  • Inputs
  • Outputs
  • Sync & MIDI
D: internal sound generation
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Display Brightness
  • Info
  • System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
