MOD Duo X User Guide
The MOD Duo X when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
Headphone/CV Output
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
  • width: 163 mm
  • length: 188 mm
  • height: 63 mm
  • Off: below -40dB
  • Red: between -1dB and 0dB
The MOD Duo X includes a pagination system that gives you access to 6 pages of assignments. This means that the 8 knobs, 2 endless knobs and 4 buttons are actually 48 knobs, 12 endless knobs and 24 buttons.
From the 3 performance buttons on the MOD Duo X, you can set if you use 1 to switch between pages and 2 for Instant Snapshots, or 2 to switch pages and 1 for the Instant Snapshots.
1 Button
2 Button
  • 1st page: red
  • 2nd page: yellow
  • 3rd page: cyan
  • 4th page: pink
  • 5th page: orange
  • 6th page: green
The MOD Duo X has a true bypass circuit for each pair of inputs/outputs. This allows you to physically connect input 1 to output 1, and input 2 to output 2. The true bypass is enabled when the device is off and it is automatically disabled after the current pedalboard is loaded.
Pressing and holding the left endless knob will open the Device Settings menu.
