MOD Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
Headphone/CV Output
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- width: 163 mm
- length: 188 mm
- height: 63 mm
The MOD Duo X includes a pagination system that gives you access to 6 pages of assignments. This means that the 8 knobs, 2 endless knobs and 4 buttons are actually 48 knobs, 12 endless knobs and 24 buttons.
From the 3 performance buttons on the MOD Duo X, you can set if you use 1 to switch between pages and 2 for Instant Snapshots, or 2 to switch pages and 1 for the Instant Snapshots.
1 Button In this mode, only the central button will swap between pages, and therefore, you don't have immediate access to a particular page.
2 Button In this mode, the left-most and the right-most performance buttons are used to scroll the pages. As expected, the left-most button will move down the list of pages and the right-most button will move up the list of pages.
On this mode you have access only to one Instant Snapshot (from the central performance button).
According to the pages mode that you have selected, the buttons to swap the pages will light up with colors that indicate the current page:
- 1st page: red
- 2nd page: yellow
- 3rd page: cyan
- 4th page: pink
- 5th page: orange
- 6th page: green
To change the page, simply press the button(s).
