MOD Duo X User Guide
The MOD Duo X when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
Headphone/CV Output
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
  • width: 163 mm
  • length: 188 mm
  • height: 63 mm
  • Off: below -40dB
  • Red: between -1dB and 0dB
The MOD Duo X allows you to switch between 3 pages of settings. This means that the 8 knobs, 2 endless knobs and 4 buttons are actually 24 knobs, 6 endless knobs and 12 buttons. When you address a plugin parameter to a MOD Duo X actuator, you can choose which page you want to address the parameter to.
The pagination button is the central button of the 3 top buttons in the MOD Duo X panel. Its light indicates the current selected page:
  • 1st page: red
  • 2nd page: yellow
  • 3rd page: green
