MOD Duo X Device Settings
On the right screen, you can turn bypass on and off independently for channels 1 and 2 or for both.
This option allows you to tune your instrument. Both inputs can be used as the tuner input, to select between them short short-press the right endless knob.
In the settings menu, there is an indicator "Mute [x]" that you can toggle to mute your outputs or not while tuning. Press the left knob to change this value.
A: line level input
- Sync & MIDI
- Sync & MIDI
C: mic level input
- Sync & MIDI
D: instrument level input
- Sync & MIDI
- I/O Processing
- Sync & MIDI
- Bluetooth
- Device Settings
- Info
- System Upgrade
I/O Processing
- Off: the compressor will remain deactivated
- Light: there will be a light compression applied to the output
- Mild: there will be a mild compression applied to the output
- Heavy: there will be a heavy compression applied to the output
Clock Source
This option allows you to select the Clock source on your device.
The Clock Source can be either Internal, MIDI, or Ableton Link.
Send MIDI Clock
SHAPSHOT NAV MIDI CHAN
Here, you can set the MIDI channel to be used with an external controller to change the snapshots saved on your loaded pedalboard.
If the channel is set to anything except OFF, the device will listen for Program Change messages on the selected channel. The incoming message value will be used as the index of the snapshot to load from the pedalboard. This means that if PC 1 is issued, the first snapshot will be loaded, if PC 2 is received, the second snapshot will be loaded, and so on.
PEDALBOARD NAV MIDI CHN
Here, you can set the MIDI channel to be used with an external controller to change the pedalboard.
If the channel is set to anything except OFF, the device will listen for Program Change messages on the selected channel. The incoming message value will be used as the index of the pedalboard to load from the current bank. This means that if PC 1 is issued, the first pedalboard will be loaded, if PC 2 is received, the second pedalboard will be loaded, and so on. Pedalboards can be reordered using the Web interface.
USB-B Mode
Display Contrast Left & Right
Pages Mode
LED Brightness
Pot Calibration Mode
