MOD Duo X Device Settings
On the right screen, you can turn bypass on and off independently for channels 1 and 2 or for both.
This option allows you to tune your instrument. Both inputs can be used as the tuner input, to select between them short short-press the right endless knob.
In the settings menu, there is an indicator "Mute [x]" that you can toggle to mute your outputs or not while tuning. Press the left knob to change this value.
A: line level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
C: mic level input
  • Inputs
  • Outputs
  • Sync & MIDI
D: instrument level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • I/O Processing
  • Sync & MIDI
  • Bluetooth
  • Device Settings
  • Info
  • System Upgrade
I/O Processing
  • Off: the compressor will remain deactivated
  • Light: there will be a light compression applied to the output
  • Mild: there will be a mild compression applied to the output
  • Heavy: there will be a heavy compression applied to the output
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
USB-B Mode
  • Network (Default): The port works as a network device, so you can access the WebGUI.
  • Net+MIDI: The port works as a network device, so you can access the WebGUI. Simultaneously, the device sends MIDI messages via this port and therefore, is also recognized as a MIDI interface.
  • Net+MIDI (Windows): The port works as a network device, so you can access the WebGUI. Simultaneously, the device sends MIDI messages via this port and therefore, is also recognized as a MIDI interface. Special mode to use when the host device is a Windows computer.
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Display Contrast Left & Right
Pages Mode
LED Brightness
Pot Calibration Mode
