MOD Duo X Device Settings
On the right screen, you can turn bypass on and off independently for channels 1 and 2 or for both.
A: line level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
C: mic level input
  • Inputs
  • Outputs
  • Sync & MIDI
D: instrument level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • I/O Processing
  • Sync & MIDI
  • Bluetooth
  • Device Settings
  • Info
  • System Upgrade
Note: there is a shortcode for controlling the master output volume. Press and hold the right endless knob to activate the Master Volume control mode. While you keep pressing, turn the knob to adjust the volume. Release it to exit this mode.
I/O Processing
  • Off: the compressor will remain deactivated
  • Light: there will be a light compression applied to the output
  • Mild: there will be a mild compression applied to the output
  • Heavy: there will be a heavy compression applied to the output
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
USB-B Mode
  • Network (Default): The port works as a network device, so you can access the WebGUI.
  • Net+MIDI: The port works as a network device, so you can access the WebGUI. Simultaneously, the device sends MIDI messages via this port and therefore, is also recognized as a MIDI interface.
  • Net+MIDI (Windows): The port works as a network device, so you can access the WebGUI. Simultaneously, the device sends MIDI messages via this port and therefore, is also recognized as a MIDI interface. Special mode to use when the host device is a Windows computer.
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Display Contrast Left & Right
Pages Mode
LED Brightness
Pot Calibration Mode
