MOD Duo X Device Settings
A: line level input
- Sync & MIDI
- Sync & MIDI
C: mic level input
- Sync & MIDI
D: instrument level input
- Sync & MIDI
- I/O Processing
- Sync & MIDI
- Bluetooth
- Device Settings
- Info
- System Upgrade
Note: there is a shortcode for controlling the master output volume. Press and hold the right endless knob to activate the Master Volume control mode. While you keep pressing, turn the knob to adjust the volume. Release it to exit this mode.
I/O Processing
- 'Noisegate Channel': allows you to activate a noise gate either right after the input 1, the input 2 or both. By selecting "none", the noisegate will remain deactivated.
- 'Noisegate Threshold': allows you to define the threshold level (in dB) of your input noisegate.
- 'Noisegate Decay': allows you to define the decay level (in milliseconds) of your input noisegate.
- 'Compressor Mode': here you can activate a compressor right before the output of your MOD Duo X. For this compressor, you have 4 different modes:
Off, Light, Mild and Heavy.
- Off: the compressor will remain deactivated
- Light: there will be a light compression applied to the output
- Mild: there will be a mild compression applied to the output
- Heavy: there will be a heavy compression applied to the output
- 'Compressor Release': allows you to define the release level (in milliseconds) of your input compressor.
- 'Pedalboard Gain': here you can select a general gain level applied to all your pedalboards. That's a different type of gain than the output gain of your MOD Duo X
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
USB-B Mode
Display Contrast Left & Right
Pages Mode
LED Brightness
Pot Calibration Mode
