MOD Duo X Device Settings
A: line level input
- Sync & MIDI
- Sync & MIDI
C: mic level input
- Sync & MIDI
D: instrument level input
- Sync & MIDI
- I/O Processing
- Sync & MIDI
- Bluetooth
- Device Settings
- Info
- System Upgrade
Note: there is a shortcode for controlling the master output volume. Press and hold the right endless knob to activate the Master Volume control mode. While you keep pressing, turn the knob to adjust the volume. Release it to exit this mode.
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
USB-B Mode
Pages Mode
Pot Calibration Mode
