MOD Duo X Device Settings
Revision as of 08:59, 4 August 2025 by Joao.sensiguitar (talk | contribs) (Created page with "= Overview = These are the Settings you can access and control directly in your device, even when you are disconnected from your computer: File:DUOX-Settings_Banks.png|400...")
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
MOD DUO
A: line level input
  • Inputs
  • Outputs
  • Sync & MIDI
B: instrument level input
  • Inputs
  • Outputs
  • Sync & MIDI
C: mic level input
  • Inputs
  • Outputs
  • Sync & MIDI
D: internal sound generation
  • Inputs
  • Outputs
  • Sync & MIDI
A: line level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
C: mic level input
  • Inputs
  • Outputs
  • Sync & MIDI
D: instrument level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Pages Mode
Pot Calibration Mode
