Dwarf User Guide
Revision as of 14:41, 31 October 2024 by Joao.sensiguitar (talk | contribs) (→‎Accessing via Bluetooth)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
The MOD Dwarf when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
  • Use supplied adapter only
Concepts and Modes
USB Host port (USB port A)
MIDI I/O
For example:
Menu button
Display
Control Mode
Navigation Mode
Tool Mode
Tempo
  • Off: below -40dB
  • Red: between -1dB and 0dB
