MOD Web GUI User Guide
Revision as of 09:34, 16 September 2024 by Joao.sensiguitar (talk | contribs)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
For MOD Desktop: http://127.0.0.1:18181/
Creating a pedalboard
MOD Duo
MOD Duo X
MOD Dwarf
  1. Pedalboard name
  2. Pedalboard actions bar
  3. Inputs
  4. Pedalboard constructor
  5. Outputs
  6. Plugins bar
MOD DUO MOD DUO X MOD DWARF
On the left edge of the constructor area (section 3) of the MOD DUO Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input. On the left edge of the constructor area (section 3) of the MOD DUO X Web GUI there are 5 connectors: 2 audio inputs, 1 MIDI input, 2 CV inputs and 1 expression pedal input. On the left edge of the constructor area (section 3) of the MOD Dwarf Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input.
On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output. On the right edge (section 5) there are 5 connectors: 2 audio outputs, 1 MIDI output and 2 CV outputs. On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output.
All those connectors represent the real inputs and outputs of your MOD device.
Adding and connecting plugins
                   |-> meter
Adjusting plugins parameters
Assigning plugins parameters
Removing an assignment
Other MOD devices
Advanced Settings
  • The assignment mode (Latching, Momentary On or Momentary Off)
Saving / loading pedalboard snapshots
You have the possibility to save the combination of parameter adjustments as a pedalboard snapshot. In order to do so, turn on the pedalboard snapshot mode by clicking on SnapshotsButton.png. Find it on the pedalboard actions bar.
A single click on the pedalboard image or name will load it to the constructor. To delete a pedalboard click on its trash icon Trash on the right of the pedalboard name.
Installing new plugins
Sharing a pedalboard
The MOD Duo and MOD Duo X have a true bypass circuit for each pair of input/output. This allows you to physically connect input 1 to output 1, and input 2 to output 2. The true bypass is enabled when the device is off and it is automatically disabled after the current pedalboard is loaded.
You can enable or disable the true bypass directly the GUI using the two bypass buttons Gui-bypass.png in the status bar. As a second option, you can control the true bypass using a special plugin called Hardware Bypass.
MOD DUO MOD DUO X
Advanced Settings
MOD DUO MOD DUO X
Dangerous
Device Updates
