Troubleshooting
Revision as of 17:29, 7 August 2024 by FalkTX (talk | contribs)
Windows doesn’t recognise MOD as you plug it
Certain Windows systems don't recognise the MOD as a network device or fail to find the correct driver.
Can't connect to the Web GUI in macOS
If you are not able to connect to your MOD device using macOS, please make sure that your computer didn't enter sleep mode while you had your MOD device connected via USB.
MOD does not boot, stuck on 'MOD Dwarf' screen
References on Ground Loops:
Site LOCAL
Accept from LOCAL
Deny
Dealing with noise issues
Issues updating the MOD Footswitch
