Stable Releases
1.13 2023/03/07 Separation of User vs Factory content; Update base toolchain; Add Bluetooth + WiFi firmware Duo: modduo-v1.13.1.3122.tar
Duo X: modduox-v1.13.1.3123.tar
Dwarf: moddwarf-v1.13.1.3124.tar
Duo X: modduox-v1.7.4.855.tar
  1. Turn on your MOD
  2. Let it boot until you see it load a pedalboard
  3. Enter the settings menu
    1. For the MOD Dwarf, press the menu button left of the display and press the middle of the 3 small buttons on the right of the display to enter settings.
    2. For the MOD Duo(X) press and hold the left endless-knob until a menu appears in the display
    1. Note -> for the MOD Duo(X), turn the left knob to the "System" option and then the right knob to "System upgrade"
  5. Select 'YES' and while holding footswitch A (Dwarf), the left footswitch (Duo) or bottom left square button (DuoX)
User data will remain untouched. If you wish to also restore your user data, please install one of the images here: https://wiki.mod.audio/wiki/Factory_Reset_Images
Release 1.13
v1.13.2
Work-in-progress!
  • Allow *.aidax and *.nam file extensions
  • Allow pedalboard share recording up to 3 minutes
  • Fix automatic updates for Duo X LE units coming from old releases
  • Fix category hide responsiveness
  • Fix error dialog appearing when re-selecting the active transport sync mode
  • Fix parameter changes blocking web gui updates
  • Fix pedalboard screenshots with invalid plugin data (recreate cache as needed)
  • Fix race condition leading to missing plugin param triggers
  • Fix tempo labels
  • Improve icon.html used for modgui screenshots (see https://github.com/moddevices/mod-screenshot)
  • Improve pedalboard search data
  • Minor optimization tweaks
  • Show text selection in plugin information dialog
  • Skip reset confirmation dialog for remote pedalboard loading
v1.13.1
Released on 2023/03/07
  • Fix MIDI program changes not matching loaded pedalboard (Duo and Duo X specific)
  • Fix performance regressions in 1.13.0 (downgrade glibc to 2.27, more system-level tweaks)
  • Relocate transport to frame 0 on playback stop
Dwarf specific:
  • Fix selected pedalboard mismatching when removing pedalboards from banks on the device
  • Fix a newly created bank becoming the active bank when created on the device
v1.13.0
Released on 2023/02/27
Dwarf specific:
  • Fix loading PBs from MIDI PC when no bank has been selected (v1.13-RC1 regression)
  • Fix system info and bluetooth device dialogs not showing (v1.13-RC1 regression)
v1.13-RC1
Released on 2023/02/13
  • Add a few handy modgui javascript utilities (get_custom_resource_filename, get_port_index_for_symbol, get_port_symbol_for_index), bump API version to 3
  • Add plugin-specific "aidadspmodel" file type
  • Add Bluetooth and WiFi firmware
  • Adjust UAC2 gadget name and buffering details
  • Allow to privately share a pedalboard (new checkbox in share dialog)
  • Allow "see discussion" button on plugin information dialogs
  • Fix Duo name in Duo X and Dwarf zeroconf service names
  • Fix pedalboard screenshot generation
  • Fix trial watermark for systems without Arial font
  • Log exceptions thrown by modgui javascript code
  • Speed up pedalboard listing
  • Send "end" event to modguis just before deletion
  • Update Duo and Dwarf kernel to 6.1.11
  • Update base compiler and toolchain to gcc9 and glibc2.38 (NOTE: 1.13.1 downgraded glibc to 2.27 due to performance regression)
Dwarf specific:
  • NEW: Split factory and user pedalboards and banks
  • Auto-delete banks.json and pedalboards in user data when they match factory content
  • System-level tweaks to make CPU load more consistent
Release 1.12
v1.12.2
Released on 2023/01/17
v1.12.1
Released on 2022/12/21
v1.12.0
Released on 2022/12/01
  • fix memory leaks
Duo X specific changes:
v1.12-RC3
Released on 2022/07/05
v1.12-RC2
Released on 2022/06/08
Duo X specific:
Dwarf specific:
v1.12-RC1
Released on 2022/05/20
  • many system tweaks
Duo X specific: (all units)
Dwarf specific:
  • NEW: LED brightness option
v1.11.6
v1.11.5
Released on 2022/05/05
v1.11.4
Released on 2022/04/08
Dwarf specific (device side):
v1.11.3
Released on 2022/03/11
  • add "/allguis" special page
Dwarf specific:
v1.11.2
Released on 2022/02/11
Duo X specific:
Dwarf specific:
v1.11.1
Released on 2022/01/28
Dwarf specific:
v1.11.0
Released on 2021/12/23
Released on 2021/12/17
Released on 2021/11/16
  • NEW: Virtual MIDI Loopback
  • Add button color for banks
  • New MOD Dwarf logo
  • Add opus audio file support
  • NEW: MOD Dwarf support
  • General UI improvements
  • New device screen layout
  • New font
  • Fix sporadic boot issues
  • fix disabling snapshots
  • minor UI fixes
  • small cosmetic fixes
  • NEW: Actuator groups
  • Support for new Duo X unit
  • MIDI Clock slave and output
  • Unlocked parameters
  • User profiles
  • Fixed small all around bugs
  • Renaming unstable -> beta
  • Settings button
  • Minors
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
