MOD Web GUI User Guide
Connect your MOD device to your Linux, Windows or MacOS device using the USB cable which you received with your device. The operating system should recognize your unit as a network device and configure it automatically. In some cases, if it does not work, it can help to turn the device off and on again, keeping the USB cable connected. If it still doesn't work, please check the troubleshooting page.
If you are connecting via Bluetooth, visit http://192.168.50.1.
Creating a pedalboard
MOD Duo
MOD Duo X
MOD Dwarf
  1. Pedalboard name
  2. Pedalboard actions bar
  3. Inputs
  4. Pedalboard constructor
  5. Outputs
  6. Plugins bar
MOD DUO MOD DUO X MOD DWARF
On the left edge of the constructor area (section 3) of the MOD DUO Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input. On the left edge of the constructor area (section 3) of the MOD DUO X Web GUI there are 5 connectors: 2 audio inputs, 1 MIDI input, 2 CV inputs and 1 expression pedal input. On the left edge of the constructor area (section 3) of the MOD Dwarf Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input.
On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output. On the right edge (section 5) there are 5 connectors: 2 audio outputs, 1 MIDI output and 2 CV outputs. On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output.
All those connectors represent the real inputs and outputs of your MOD device.
Adding and connecting plugins
                   |-> meter
Adjusting plugins parameters
Assigning plugins parameters
Removing an assignment
Other MOD devices
Advanced Settings
  • The assignment mode (Latching, Momentary On or Momentary Off)
Saving / loading pedalboard snapshots
You have the possibility to save the combination of parameter adjustments as a pedalboard snapshot. In order to do so, turn on the pedalboard snapshot mode by clicking on SnapshotsButton.png. Find it on the pedalboard actions bar.
A single click on the pedalboard image or name will load it to the constructor. To delete a pedalboard click on its trash icon Trash on the right of the pedalboard name.
Installing new plugins
Sharing a pedalboard
MOD DUO MOD DUO X
Advanced Settings
MOD DUO MOD DUO X
Device Updates
