Troubleshooting Reinstall via LiveSuit
Revision as of 13:28, 15 March 2023 by FalkTX (talk | contribs)
Different MOD Duo models
This procedure applies only to older MOD Duo units with nand flash! (those without "MOD Duo" written on the top-right of the unit)
  1. Click and hold down the FEL button on the back of the MOD Duo (in tiny hole), while you power it on
  4. Download https://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
  7. Wait for the Duo to have blue LEDs and install Duo factory reset image (see #Step 7: Finalizing below)
Continue to step 6.
Continue to step 8
Step 7: Finalizing
5. Wait until the installation finishes (unit will flicker the screens a bit when about finish
