Troubleshooting Reinstall via LiveSuit
Revision as of 13:27, 15 March 2023 by FalkTX (talk | contribs)
Different MOD Duo models
This procedure applies only to older MOD Duo units with nand flash!
  1. Click and hold down the FEL button on the back of the MOD Duo (in tiny hole), while you power it on
  4. Download https://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
  7. Wait for the Duo to have blue LEDs and install Duo factory reset image (see #Step 7: Finalizing below)
Continue to step 6.
Continue to step 8
Step 7: Finalizing
5. Wait until the installation finishes (unit will flicker the screens a bit when about finish
