Troubleshooting Reinstall via LiveSuit
Just follow these steps one by one:
Continue to step 6.
Continue to step 8
Step 8: Finalizing
5. Wait until the installation finishes (should take around 10 minutes, the Duo will automatically reboot afterwards)
