Troubleshooting Reinstall via LiveSuit
Just follow these steps one by one:
  1. Click and hold down the FEL button on the back of the MOD Duo (in tiny hole), while you power it on
  4. Download https://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
  7. Wait for the Duo's restore mode to activate
  8. Download the Duo image from Factory Reset Images and copy it to the mass storage device (as usual for MOD updates)
  9. Wait until the installation finishes (the Duo will automatically reboot)
Continue to step 6.
Continue to step 8
Step 8: Finalizing
1. Download the Duo image from Factory_Reset_Images and copy it to the mass storage device (as usual for MOD updates)
2. Wait until the installation finishes (the Duo will automatically reboot)
