Troubleshooting Reinstall via LiveSuit
Just follow these steps one by one:
Continue to step 6.
Continue to step 8
Step 8: Finalizing
1. Download the Duo image from Reset Images and copy it to the mass storage device (as usual for MOD updates)
2. Wait until the installation finishes (the Duo will automatically reboot)
