Troubleshooting Reinstall via LiveSuit
- Run LiveSuit and deploy the MOD Duo LiveSuit image (see #Deploying LiveSuit image below)
Step 5: Installing FEL mode USB driver
Continue to step 6.
Step 6: Deploying LiveSuit image
Continue to step 8
Step 8: Finalizing
